I have Stihl weedeater. I push the primer button 3 times, put the choke on and pull - it starts right up. I take the choke off and the unit runs as it should. After approximately 5 minutes of normal use the engine starts to oscillate (normal rpm to low rpm to normal rpm) then run as if it wants to die. By constantly depressing and releasing the accelerator lever I can keep the thing running for a while but after about 8 minutes of running erratic it dies.
The only thing I can think of that is causing this is some type of heat related issue - that is once the engine heats up the issue occurs.
