stihl ms290 won't start
   / stihl ms290 won't start #1
MississippiMan
Bronze Member
Mississippi
Mahindra 5525
I had broken some plastic pieces on the housing and chain brake so I replaced them. While doing so I removed the carb and cleaned it. Put it all back together and it started normally and then quit in about 2-3 seconds. It did this 5-6 times. It would never idle on it's own. So I got the service manual and removed the carb again meticulously making sure I reassembled everything correctly and installed the carb correctly. Hoses, lines,electrical, everything by the book. Carb was already properly adjusted but I checked that too.
Now it won't turn over and eventually after many pulls I saw gas spray out of the muffler. So I removed it and I am drying that out at the moment. I guess I flooded the engine but why? Possibly getting no spark. I'll have to check for that next but I have an appointment to keep now.
Any ideas would be appreciated.
Every line and every screen and filter is clean and it appears to be ample fuel.
Help. It was running great when I put it away last week.:confused:
   / stihl ms290 won't start #2
Sparkplug is most likely fouled. Check sparkplug wire for break or no contact. Check the on/off switch. Depending on how the pieces ended up broken could identify other damage (broken wires, etc.).
   / stihl ms290 won't start #3
Also inspect the black accordion like fuel hose, they are known to split .
spark plug is new with correct gap. Will give close look at fuel line and wiring in the morning.
   / stihl ms290 won't start #5
Is the fuel fresh?
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
2007 JLG SkyTrak 10042 10,000lb 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
City of Lakeland (A51691)
City of Lakeland...
2003 Honda Element SUV (A50324)
2003 Honda Element...
