Stihl Hedge Trimmer, Which doggone one?
   / Stihl Hedge Trimmer, Which doggone one? #1
TomSeller
Super Member
JD, Massey, Kubota, Case
I am looking at getting a Stihl professional hedge trimmer (I typically buy professional Stihl). I expected the line up to be like chainsaws where the power and weight went up with the model line. They seem to all be about the same power and weight. (Weight is obviously a design factor). Any advice out there? Mostly needed for maintenance pruning.
   / Stihl Hedge Trimmer, Which doggone one? #2
I have three Stihl hedge trimmers. The first one is a dedicated trimmer with the space between the teeth fairly large. It will eat thicker branches very well and it is not heavy. However, it is usually the wife who trims hedges while I am at work, and she is vertically challenged and has a tough time with the dedicated machine. We also have the Stihl power head system. That way we can swap out the implements and save some money on power tools.
We have two Stihl implements for hedge trimming that fit with those power heads. One is a straight implement that gave my wife some reach with the trimmer, and it worked well for her for most things. However, there were times when she did not have the right angle she wanted. In all fairness, that is only because she wanted to use the hedge trimmer to trim off saplings sprouting up around tree roots. She wanted to use it as a weed eater. We bought the hedge trimmer that has the adjustable head so it mounts at an angle. It is also very handy for tall hedges when I want to trim the top off.
Since my wife has shoulder trouble (as well as I), I got here the recoil start power head which has lower horsepower than mine. Either one runs the trimmers well.
The dedicated on with the wide tooth spacing? Not heavy and plenty of power.
The power head models are heavier but have longer reach and narrower spacing between teeth, so they don't cut the thicker branches as well.
On your dedicated trimmer, do you recall the model? And does it have teeth on both sides of the bar?
   / Stihl Hedge Trimmer, Which doggone one? #4
It is the HS56C. There is a video of the review on YouTube, but I can't link it because of my low post count.
It has teeth on both sides of the bar.
   / Stihl Hedge Trimmer, Which doggone one? #5
I have the Kombi system bye Stihl. I love it. I got the adjustable hedge trimer head it works great. it is on the heavy side.
I have the Kombi system as well and it is great. I use it for weed eating, brush blading, pole sawing and hedges and it does a super job. However when I am going to trim in tight spaces close to my body I really need to replace my electric hedge trimmer. Just tired of the extension cord and have too much work for a rechargeable.
   / Stihl Hedge Trimmer, Which doggone one? #7
I can recommend the HS45. It is fairly light, but I've been impressed with its capabilities. I just used it to cut back blackberry bushes. Even on the thicker stuff, it the blades can get to it, the HS45 will cut it.
FRONTIER CA2072 LOT IDENTIFIER 32 (A53084)
FRONTIER CA2072...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
