Stihl FS55R Weedeater
   / Stihl FS55R Weedeater #1
artrip
My Stihl FS55R will not open up when you try to give it full throttle it dies, I rebuilt the Zama Carb and it still does the same thing.
   / Stihl FS55R Weedeater #3
+1 on the spark arrester plus check your in-tank fuel filter and fuel lines. Did you replace the filter screen in the carburetor and adjust the metering diaphragm rocker? Go to Zama's web site and read the technical hints. New carbs are only about $50 now. Don't rule out the spark plug as part of the problem.
Jim
Thanks guys I took the spark arrester screen out and it cranked right up and runs great now, would it be ok to run it like that or do i need to pick one up tomorrow?
   / Stihl FS55R Weedeater #5
I have frequently run chainsaws w/o the screen. I have also heard opinions that running w/o screen decreases engine life (don't know how). I would probably get a new one for the noise if nothing else.
Jim
28013 (A50322)
28013 (A50322)
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
