Stihl dealer has no saws
   / Stihl dealer has no saws #31
2 Stihl Dealer's here in Valley , 1 is a Box store similar to TSC it is called Big R , they also sell Husky's , while the other is a saw / small engine equipment shop . I go through the small shop , they have been in business since I was in high school , use to buy my gear and logging clothing there back then while I was still in High school Forestry class .
Fred H.
   / Stihl dealer has no saws #32
I stopped my my dealer today to get some oil. A Mom and Pop dealer with great service. He had three saws on the wall. This spring it was full.
I asked why so few. He said Stihl now requires you to pay up front before you sell them and he did'nt have enough cash to stock the wall.
Does this mean only big dealers will survive?
I am a Stihl user and really like my Stihl saws, etc. But if I couldn't find a Stihl I'd check out TSC since they have started carrying Jonsred around here. Ive heard good stuff about Jonsred saws.
   / Stihl dealer has no saws #33
Number of dealers for a given saw has a lot of variables. Do you have to buy in at a certain level? How much is the wholesale vs the retail? Whats the avg customer in the area buying? Denver dealers don't sell a bunch of $600 pro level stihls or huskys. They buy $150 echos to cut a branch or two a year. When you buy a pro level saw, your probably not buying another for while, so its a low turnover market whereas box store saws get higher turnover and re purchase. Tru Value used to be a Husky dealer and they have all switched to stihl in our area. I had to go to a small mom and pop husky dealer to get the saw I wanted.
   / Stihl dealer has no saws #34
TSC will be selling another type saw next year. The same thing can be said about their welders, and air compressors. They even switched battery suppliers recently.
   / Stihl dealer has no saws #36
As far as what chainsaw to purchase, I would recommend something about 50cc. The Stihl 026/MS260/MS261, Husqvarna 346 or the newer variants, and others.
When you say 36" tree, that's a biggun but if it's one tree vs a size you will encounter on a regular basis makes a big difference. If you are regularly encountering 36" wood you are really into the 90cc area of saw size which would be the Stihl 066/MS660 and the Husqvarna 390/395 and variants.
If you have a one tree situation or a "might have a tree that size" don't let that impact your decision too much. A saw in the 50cc class will be an all around saw and cut most of the firewood size stuff most people encounter.
An 18" bar will enable you to buck up just about any size wood by making noodling cuts as you buck. Not the fastest but works for the occasional large tree.
I have more than 10 chainsaws at any one time ranging from 30 something cc to over 100. The 50cc saws do 90% of my cutting.
I favor Stihls and have a lot of those but also have Husqvarna, Jonsered, Poulan, McCulloch, Homelite, etc. The brand of saw you buy is not the most critical issue. The most important thing relating to chainsaw longevity is to use a fresh batch of properly mixed fuel and of utmost importance, keep your chain sharp. If you treat a saw like the typical homeowner does which is to cut up the broken tree, put the saw on the shelf for x years and then get it out and run it (or attempt to) on the stale mix with a dull chain, you will be adding that saw to the junk heap and getting a new one. Most of the "throw away" saws spoken of aren't really all that bad mechanically, it is the typical treatment they are subjected to. You can buy the most expensive "pro" saw out there and if you treat it poorly, you will have the exact same problems as the $99 saws. Treat the pro saw and the $99 saw well and they will both serve you well. Most pro saws don't get thrown away because they are so expensive to replace, they get fixed.
So if you are going to have one saw, the 50cc class is where you need to start. Then add a larger and smaller saw later if you find you could benefit from it.
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
Schulte SBW800 Rock Windrower (A55314)
Schulte SBW800...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
