Stihl 441 Clutch/Chainbrake issue
   / Stihl 441 Clutch/Chainbrake issue #11
I agree with others that the idle wasn't properly set. At idle, the clutch weights should not even be getting thrown out against the drum, so whether the brake is on or off shouldn't matter at all. If the clutch burnt out at idle, then the idle was way too high.
A good visual test to use *every time* you run a saw is to make sure the chain does not move when the saw idles. If it does, that is a red flag that the carb needs tuning or the idle needs adjustment. It's also a big safety issue.
2007 Ford E-350 Passenger Van (A56858)
2007 Ford E-350...
2233 (A58376)
2233 (A58376)
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
EquipmentDealz (Preview Dates and Times) (A59213)
EquipmentDealz...
