Stihl 012 - Too much oil
   / Stihl 012 - Too much oil #1
CHDinCT
Conn. & Florida
Kubota BX25, Z422-KW
Been having this issue for a while and haven't found any similar posts doing a Google search. My 1990 Stihl 012 Avq goes through a tank of oil about as fast as the fuel mix. You can actually see it fling oil (I mean a lot of oil; I know some discharge is normal) on a fast rev up in RPM. Can't find out anything about an oil pump adjustment. Seems like 99% of the issues involve no or too little oil. I'm not a real chain saw geek so appreciate any suggestions on simple solutions before I have a dealer look at. It's my backup saw now, but it would be nice to have it working correctly if it's nothing too complicated/expensive to repair. Thanks
   / Stihl 012 - Too much oil #2
Some saws have an adjustment, though I don’t think that one does? Anyways, a tank of oil to a tank of gas seems about normal to me.
   / Stihl 012 - Too much oil #4
As MMagis says, a tank per tank of bar oil to fuel is about right. When you hold the bar tip over & pointed at a light colored object (stump) and run the saw at half throttle you're supposed to see oil fling off the chain & onto the stump. Sounds like you're saw is OK.
Do a search for "Sharp Advice for Chainsaw Owners" and download the pdf. Its a very good owner's operating guide by Stihl. Page 7 describes the bar lube check.
   / Stihl 012 - Too much oil #6
I like my saws to use almost a tank of bar oil to a tank of mix. Nothing wrong with that IMO and mine fling oil too.
It's the newer stingy ones that worry me.
   / Stihl 012 - Too much oil #7
I have an Stihl 012 and it is just as you say. One other thing to mention that I noticed is that it will pump bar oil out while idling. I always shut it off if not cutting. The other thing I do is put a little less than full tank of fuel so it always runs out of fuel before it runs out of bar oil.:thumbsup:
OK guys, guess I'll not worry about it too much but it's my recollection that it didn't use this much oil until a year or so ago. It will leave an oily mess at the bottom of the saw case every time I take it out.
dex, I like this idea and will proceed on that basis. I think I've been doing that subconsciously now by not topping off the mix without thinking about it. Thanks
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
40 Gun Fireproof Safe (New/Unused) (A59225)
40 Gun Fireproof...
MASSAGE CHAIR (A58216)
