Stiff 3 point lever
/ Stiff 3 point lever #1
rwork
Platinum Member
Mississippi Gulf Coast
Kubota B6100 LS R3039H
My 3point lever is stiffer than what I'd like. It's like it has a bit too much resistance. I like to feather my control as I'm working, and have to rest the side of my hand against the fender, in order to ease the lever a little bit. Anyone else have this problem? I tried to spray some white lithium onto the linkage, through the lever slot. I can't see any easy way to get to the linkage to grease it up.
/ Stiff 3 point lever #2
Had a similar issue at about 300 hours on my kubota I ended up taking the whole plastic cover and boot out found the dirt and grime build up on on the actuator cylinders above where the cable attaches. Cleaned it up and lube it works fine now
I guess I need to take a closer look, and see how to acess the linkage. Would sure like to get it slicked up where I can move it smoothly.
/ Stiff 3 point lever #4
It has been my experience that White Lithium Grease is the worst thing ever to use on anything that is outdoors. Good old fashioned WD40 has always worked for me, you have to reapply it every so often but it works and don't collect every bit of crap that blows by.
Might try some fluid film. It's pretty slick stuff.
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
UNUSED IRMC HIGH-END MASSAGE CHAIR (A64281)
UNUSED IRMC...
2023 MANITECH MTECH-2.0T TELESCOPIC WHEEL LOADER (A64279)
2023 MANITECH...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61573)
2011 Energy...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
