Stiff 3 point lever
   / Stiff 3 point lever #1
rwork
Platinum Member
Mississippi Gulf Coast
Kubota B6100 LS R3039H
My 3point lever is stiffer than what I'd like. It's like it has a bit too much resistance. I like to feather my control as I'm working, and have to rest the side of my hand against the fender, in order to ease the lever a little bit. Anyone else have this problem? I tried to spray some white lithium onto the linkage, through the lever slot. I can't see any easy way to get to the linkage to grease it up.
   / Stiff 3 point lever #2
Had a similar issue at about 300 hours on my kubota I ended up taking the whole plastic cover and boot out found the dirt and grime build up on on the actuator cylinders above where the cable attaches. Cleaned it up and lube it works fine now
I guess I need to take a closer look, and see how to acess the linkage. Would sure like to get it slicked up where I can move it smoothly.
   / Stiff 3 point lever #4
It has been my experience that White Lithium Grease is the worst thing ever to use on anything that is outdoors. Good old fashioned WD40 has always worked for me, you have to reapply it every so often but it works and don't collect every bit of crap that blows by.
Might try some fluid film. It's pretty slick stuff.
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
2014 International Pro Star Semi (A50514)
2014 International...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
