Sticky on Water in Hydraulic Fluid?
   / Sticky on Water in Hydraulic Fluid? #1
Belchos
Redding, CA
1982 M4000
I have found a huge amount of water in my hydraulic fluid. I drained it and wiped out the reservoir tank, and will purchase and go through a couple filters and a lot of fluid today to try to purge. Looking for more help. Could not find a sticky or FAQ on this although I suspect it has come up often. Panicked. :eek:
   / Sticky on Water in Hydraulic Fluid? #2
Just do like you have mentioned,and run the cylinders through many cycles.
You need to find the source of the water leak. If left outside, at least throw a tarp/plastic over the tractor.
   / Sticky on Water in Hydraulic Fluid? #3
Welcome to TBN:D
I think you got it figured out...You need to flush the system AND find the source. You can use some cheap fluid till you get it flushed...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
Landoll Hauloll (A53472)
Landoll Hauloll...
2024 JOHN DEERE 6135E LOT IDENTIFIER 244 (A53084)
2024 JOHN DEERE...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
