Sticky on Water in Hydraulic Fluid?
   / Sticky on Water in Hydraulic Fluid? #1
Belchos
Redding, CA
1982 M4000
I have found a huge amount of water in my hydraulic fluid. I drained it and wiped out the reservoir tank, and will purchase and go through a couple filters and a lot of fluid today to try to purge. Looking for more help. Could not find a sticky or FAQ on this although I suspect it has come up often. Panicked. :eek:
   / Sticky on Water in Hydraulic Fluid? #2
Just do like you have mentioned,and run the cylinders through many cycles.
You need to find the source of the water leak. If left outside, at least throw a tarp/plastic over the tractor.
   / Sticky on Water in Hydraulic Fluid? #3
Welcome to TBN:D
I think you got it figured out...You need to flush the system AND find the source. You can use some cheap fluid till you get it flushed...
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
2018 John Deere 1653 (A53472)
2018 John Deere...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
JOHN DEERE 4730 LOT IDENTIFIER 261 (A53084)
JOHN DEERE 4730...
