Sticking Right Brake 1980 L245DT
   / Sticking Right Brake 1980 L245DT #1
Wacimus
Northern California
1980 Kubota L245DT
Evening,
I have a brand new to me 1980 Kubota L245DT. The left brake works like a champ. The right brake goes down and won't come back up unless I reach down and yank it up. Is there an adjustment I can adjust? I'm fairly competent/confident in my mechanical abilities. I just don't want to tear into anything without a bit of knowledge first. Thanks in advance! Also, rebuilding hydraulic cylinders, hard?
   / Sticking Right Brake 1980 L245DT #2
Those brakes have a rotating shaft that gets rusted/stuck in the bores. I've used PB Blaster and worked it to free it up.
Once the gland is out of the barrel, replacing cylinder seals is reasonably easy (uses a special installation tool) If the rod or barrel has visible gouges a professional rebuild may be needed.
2017 Peterbilt 220 16FT Box Truck (A51692)
2017 Peterbilt 220...
City of Lakeland (A51691)
City of Lakeland...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
7046 (A50322)
7046 (A50322)
2017 Vicon 764 (A50123)
2017 Vicon 764...
