Sticking Right Brake 1980 L245DT
   / Sticking Right Brake 1980 L245DT #1
Wacimus
Northern California
1980 Kubota L245DT
Evening,
I have a brand new to me 1980 Kubota L245DT. The left brake works like a champ. The right brake goes down and won't come back up unless I reach down and yank it up. Is there an adjustment I can adjust? I'm fairly competent/confident in my mechanical abilities. I just don't want to tear into anything without a bit of knowledge first. Thanks in advance! Also, rebuilding hydraulic cylinders, hard?
   / Sticking Right Brake 1980 L245DT #2
Those brakes have a rotating shaft that gets rusted/stuck in the bores. I've used PB Blaster and worked it to free it up.
Once the gland is out of the barrel, replacing cylinder seals is reasonably easy (uses a special installation tool) If the rod or barrel has visible gouges a professional rebuild may be needed.
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
BUSH HOG 7007 LOT IDENTIFIER 99 (A53084)
BUSH HOG 7007 LOT...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
