sticking hst pedal ck20
   / sticking hst pedal ck20 #1
inheat
me
ck20
has anyone come up with a solution for the lack of return to the hst pedal? I have adjusted and lubricated and heated it up where it gos into the transmission still pretty dangerous.
   / sticking hst pedal ck20 #2
Try lubing initially with a light lube like WD40. Blast it in there good in an attempt to wash the area out. When this is accomplished TRY A GOOD quality white lithium grease
rim A
   / sticking hst pedal ck20 #3
I don't know how old your tractor is but anywhere a shaft goes through the trans case is suseptable to rusting and getting stiff. As mentioned, WD40, PB Blaster, or some sort of loosening oil is good to get it going. Then the white lithium to keep it there. This happened to me after my first Winter plowing. HST pedal, range selector, brakes, 3pt, all became stiff. Once loosened as mentioned, I use white lithium Spring and Winter. Good for 9 years now.
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
2013 INTERNATIONAL MA025 ROUSTABOUT (A52472)
2013 INTERNATIONAL...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
