Sticking gas pedal
   / Sticking gas pedal #1
Anonymous Poster
Epic Contributor
1999 3010 GST 260 hrs. My problem is a sticking gas pedal. Every time I use the tractor I have to spray the linkage with wd 40. Does anyone know what I can do to stop this?
   / Sticking gas pedal #2
Take it back to the dealer! Now! Tell them exchange for one with a diesel pedal /w3tcompact/icons/wink.gif
Seriously though... Check the linkage for bends. If it is tweaked slightly, it would cause that. Also, check the whole linkage path to make sure it isn't rubbing a piece of sheetmetal, or engine, or frame. Check each linkage connection point to ensure it is clean, and that bushings are clean and are still there, if applicable.
One thing to look at too, is to make sure all the linkage is clean. If you spray lube on it(ie wd40, ect), it will attract dirt and stuff, which will cause it to jam up again.
RobertN in Shingle Springs Calif
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
