Stick welder: Why DC?
   / Stick welder: Why DC? #21
Spent a few minutes looking for it and only found 1/16" 7014. My technique sucks probably.
Remembered that I have an open account at Mcmasters.com so I clicked on it. They will send me a bill. Will probably have it either tomorrow or thursday.
Next need a project.
Last question: If DC is better why does my welder weld in AC too?
!:Your welder can put out more amps on the higher AC settings. might be usefull when you have some big job to do.
2: You can weld magnetized metal with AC.. real problem with DC.. it is called arc-blow.. Your arc wander when encountering the magnetized portion of the metal. Whoa what the heck is the arc doing coming way of the side of my rod!
3: You can run a carbon torch on the AC side.
4: frozen pipe thawing on AC
5: If you do want to commit suicide.. ha ha.. run it up to the highest setting on ac and wet both hands...:)
That is about all I can think of.
James K0UA
   / Stick welder: Why DC? #23
....Last question: If DC is better why does my welder weld in AC too?
Well the answer to that is simple.
What is your Miller Thunderbolt? In simple terms and at root level it is a voltage and amp transformer. It takes your 230 volt and 40 amp household input power from your power company and converts it roughly 80 volts Open Circuit Voltage and then roughly down to 35 volts when actual welding is occuring and 225 amps AC output at your wide open setting. (Why: stick welding is a constant current process that needs low voltage and a constant high amp setting to work properly. If welding worked well at high voltage and low amps well then you could simply use a lamp cord and utilize your household power if you could figure out how to keep from electrocuting yourself or tripping a breaker. The reason OCV is limited to 80 volt by the UL is that it is considered reasonably safe from electrocution. For the most part any welder produced after 1960 is going to be reasonably safe from electrocution whether AC or DC, but you still do want to be careful. The 80 volt OCV helps the intial arc strike but then falls to roughly 30-35 volts when welding is happening).
So the absolute cheapest way to do the needed conversion for welding is to do AC (your household power is high voltage and low amp) to AC (welding is low voltage and high amp) hence why you see so many AC welders because it was the absolute cheapest way to get what was needed for welding. Of course then many people decided they want DC output just like the just like the professional grade engine driven generator welders produced as DC does have advantages. So again the absolute cheapest way to get that on a buzzbox transformer is to rectify that AC weld output to attain DC. Electrical physics dictate that there is loss in each conversion process even on the intial conversion of AC to AC which is why you have less DC output than you do AC output since your are dealing with the 3rd elctrical conversion and not the 2nd electrical conversion.
Sure there are welders that have absolutely equal AC and DC outputs but they are typically very expensive and way out of the price range of the home hobbyist plus besides cost they frequently have immense input power requirements or even 3-phase input power requirements which a standard household does not have 3-phase power.
The welding rod itself could care less whether it gets its needed power from AC or DC as either can work equally well to provide the necessary proper weld. For most people it is simply 17% easier to control all the personal human factors when using DC over AC. If you and I play basketball and shoot at 2 hoops side by side and one rim is 17% bigger then which rim will you aim at when you release the ball?
Lastly, TSC stocks 7014 (7014 burns really sweet on AC. It is the one rod that burns about equal on either one. Other rod types burn noticeabley smoother od DC and with less spatter)
   / Stick welder: Why DC? #24
I am guessing you never actually saw the puddle and learned how to move. It is like a light goes on when you finally figure out the puddle, settle down, and start seeing what the heck you are doing.. 7014, you can stick right in the puddle and drag it.
James K0UA
You have to concentrate on seeing the puddle clearly as possible (considering the presence of more or less flux in the vicinity of the puddle) and ignore the bright arc. It takes some experience to reach this point, but it's crucial to getting strong welds. That and learning to watch the edges of the puddle and adjusting your gap and rod motion to get good tie-in between the base metal and the weld material.
The Wall Mountain welding videos, especially the two on stick welding, are a good place to start if you don't have an experienced welder to guide you along. The instructor on these videos gives excellent information and demonstrations on puddle control.
Instructional Welding Videos
   / Stick welder: Why DC? #25
but have you ever had any luck with their rod..?? I have has some adverse luck with some of it. Not very smooth.
James K0UA
Works OK. I certainly cannot blame the rod for welds that look like bird poop when that does happen. I take full credit for that.
I got a chance to practice with my DC settings. Have some 7014 coming but it isn't here. I used 1/8" 6013.
I had some 3/32" mild steel and some one inch square. My Miller Thunderbolt wanted to be at full throttle 150 AMP to make a decent weld on the one inch and would do the thin material ok at about 110 but 150 looked as good.
As per suggestion I ordered 3/32" 7014, imagine that the amps can be tuned back down. At any rate the welds look to be better than I have done with the stick welder on AC.
When I first tried it I know I didn't have the welder all the way up.
Thanks to those who offered help.
   / Stick welder: Why DC? #27
The 7014 will make a pretty flat bead without a lot of ripple.. you will have to get used to moving at the right speed with it. It lays down fast, watch your arc length, not much at all, or even drag the rod. When you get good with that get some 7018.. it is cantankerous to restrike, but sure makes good strong welds.
James K0UA
I got some 3/32" 7014 and made my first weld with it. Stuck on some 1/4 steel rod onto .042" thick tubing using about 75 amps of DC. Worked very well. Smooth weld with some distortion on the back of the tubing but no burn through. It was easy.
Thanks much.
   / Stick welder: Why DC? #29
Practice more with DC
RC
   / Stick welder: Why DC? #30
Looks like you are making good progress. Practice more and watch pros weld so that you can see what the puddle should look like and get hints on positioning and material prep. I love the following link:
Down and Dirty Welding Tips | welding-tv.com
2001 Chevrolet C6500 Wrecker Tow Truck (A55852)
2001 Chevrolet...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55314)
2020 New Holland...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
