Stick Welder Hall of Fame ...
   / Stick Welder Hall of Fame ... #11
You can make some beautiful welds with some 1/16 7014 or 6013 on 1/8 inch steel sheet metal. You need a DC stick welder and you need to set the current correctly. not some old welder that has switch setting of too hot and too cold. You need precise control of the current. Practice on some same size scrap first, but the results can be very good. I have done it and you can too.
   / Stick Welder Hall of Fame ... #12
I love those little stick rods. And yes with the right hand, you can do body work. I'm not the right hand but I have seen it done.
   / Stick Welder Hall of Fame ... #13
I’ve tried both hands with little success. MIG is a blessing for less than 1/8in material. Still looking forward to learning TIG though.
   / Stick Welder Hall of Fame ... #14
If you have welded any time with gas, then TIG is a lot like that, only the Heat Affected Zone is more precise. But they are very similar.
   / Stick Welder Hall of Fame ... #15
I "know a guy" who had to shrink a set of ladder racks from an F150 to fit a Ford Ranger. He welded them up good enough to work, then cleaned up his joints with JB Weld to make them more presentable. The only bad part was when he opened a new box of rods. The older rods must have been a little damp because when I burned that first new rod using the same settings it blew a hole right through the square tubing.
They've been on the truck for 5 years...
   / Stick Welder Hall of Fame ... #16
Eastwood used to make a sheet metal attachment for a stick welder. It used 1/16 rods that were set in the gun holder with a set screw. The unit had a pistol grip like a wire feed gun, but the top was a large diode that ossilated the rod in and out of the weld puddle. The rod movement was determined by amps on the welder. It ran from 35 amps to 65 amps. It worked very well down to 16 ga, but that was about as low as I could go without perforation. I used 6013 rods with good success. 6011 rods not so good. I wonder if they still make them, or if it died with the MIG rage.
   / Stick Welder Hall of Fame ... #17
Clamp a piece of copper behind the steel being welded,,
the thin sheetmetal will weld like it is 3/8" thick,,, (10mm outside the USA!! LOL!!! )
The copper is not consumed, use it over, and over,,
I have welded 0.060" (1.5mm) thick steel with 1/8" 7014 rod,, I am not brave enough to try 7018,, but, I think it may possibly work.
No crazy low amp settings,, actually normal settings work best, it helps to melt the rod quickly, so you can travel fast,,
Occasionally, I will get the weld to stick to the copper,, but, that is seldom,,
I have a mig welder for my Miller Trailblazer,, it has been in the attic of my shed for over a decade,, I even have 3 tanks of different gas types.
but, as long as I can get to the back of the part being welded,, I clamp a piece of copper,, and weld.
Most of my copper is about 1/8" thick, easy to cut, easy to bend, I do have some pieces up to 1/2",, I use when clamping to try to make the steel flatter,,
I even add hard face weld to tiller tines, using 1/8" rod (that is what Amazon had).
The tines turned out beautiful, the weld fuses to the steel, and just sets on the copper, no bond to the copper at all.
I can make a nice sharp, extended, tine out of the worn out old "stump".
I have done two sets of Troy Bilt Horse tines,, and worn out both,, I just purchased a third set last season,, pre hard-faced.
I will weld those in about 4-6 seasons from now,, if I am still gardening,,
   / Stick Welder Hall of Fame ... #18
General Dynamics builds subs near you, at Bath Iron Works?
I thought they built only surface vessels at Bath, and Nuc subs at Groton, CT.
You are indeed correct, but the US Navy rebuilds submarines at Portsmouth Naval Shipyard. They do mostly stick welding there.
They also do some nuc sub work in Providence in addition to Groton, but Bath is only surface ships. Who does the work at Portsmouth? I assume it is some company like GD or Newport News that actually does the work for the navy,
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2009 International Ambulance (A49461)
2009 International...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
