**** stick spits oil when I shift gears
   / **** stick spits oil when I shift gears #1
Thetylerguy
Fletcher NC
2005 mahindra 3510
Hello all,
I have a mahindra 3510 shuttle shift with M,L,H and 1-4 gears. When I am driving the tractor and shift from first to second or third to fourth etc. some sort of oil shoots out of the housing that the shift stick runs down to. My question is, what kind of oil is this, and where can I add more of it?
   / **** stick spits oil when I shift gears #3
You need to read your manual. Determine how to add oil to the differential, transfer case, transmission and where the vent tube is for the differential and transmission. It sounds like the transmission and/or differential has been overfilled and the vent tube is stopped up or plugged or just blocked. When you shift gears an opportunity for venting is presented and the system being overfill with transmission fluid is given an outlet to exhaust transmission fluid.
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
