Stick Electrode Smackdown (with video)
   / Stick Electrode Smackdown (with video) #1
ChuckE2009
Hey yall!!
So, this is what I've been up to lately, I ran some welds with 6011, 6013, 7014, and 7018:
And then hammered them apart:
Which was actually pretty fun and very stress relieving. My weakest weld was 7014, then 6013, 6011, and 7018. It honestly wasn't exactly what I was expecting, but I was really impressed with how the 7018 held up, considering I ran all these with cheap Hobart electrodes and that 7018 had been sitting out since last winter. What I don't fully understand yet, tho, is the huge difference in the performance of the 70XX electrodes, how one failed so soon and the other held up so well. I know that one is low hydgren, but is that all that made the difference? Hopefully someone can shed a little light on that...
But anyway, hope yall enjoy the video :) I made this after someone asked me about weld strenght with the different electrodes, and I thought back to last summer to a series of posts made by Shield Arc. He's a great welder and did pretty much the same test that I did, so I got his permission to copy his test and made it in video form. Thanks dude :cool:
[ame=http://www.youtube.com/watch?v=QuFbvSfsMvk]Stick Electrode Smackdown - YouTube[/ame]
   / Stick Electrode Smackdown (with video) #2
List of things to look at, go back and read the manufacturer's
"As welded"
Tensile Strength, Yield Point, Charpy V-Notch Toughness, Hardness Rockwell B (avg).
   / Stick Electrode Smackdown (with video) #3
Hey, I just watched your video. I'm setting here giggling like a little girl! What's with all the misses?!
   / Stick Electrode Smackdown (with video) #4
Enjoyed the vid, and knew how it was going to turn out before you started swinging the hammer, but I was curious, in that I would have run the 7018 at 125 amps and the 7014 at 140 amps. I always though that 7014 needed more current than 7018..what say you?
James K0UA
   / Stick Electrode Smackdown (with video) #5
James K0UA
Agreed. 7014 typically likes more amps than other common rods of same diameter. I would guess 140 to 145 amps on your welder for 1/8" diameter 7014. Look at manufacturers recommendations and it will verify what we are saying.
   / Stick Electrode Smackdown (with video) #6
That doesnt surprise me in the least. I have been telling you guys here that 7014 is not a strong rod. Sure it runs pretty, but it is brittle and breaks easily and the hotter you run it the weaker it is. 7018 is a very ductile rod. Take one of each type of rod and bend a U shape in it, making the U on each one about the same length at the bottom of the U and start twisting it and count the turns before it breaks. The 7014 will snap first, then the 6013/ 6010 with be about the same and highest twist will be the 7018.
I may of told the tale about a small fab shop that I worked in briefly when I was a young kid of about 19 that made wire pulling equipment (Hycoloader in Lake Providence Louisiana). Their shop foreman loved the 7014 rod because it was so smooth and shiny and easy to weld with. My brother in law was working there with me at the time as there was a slow turn in the construction industry and jobs were kinda scarce, anyway, he had welded on a lug and had put about 4 passed on it with a 1/8" rod when the shop foreman who also did fitting came back and discovered that he had put the lug on in the wrong place and would have to be cut off. He went for a torch while my brother in law just picked up a 4 pound shop hammer and struck it about 4 times and on the final blow it went sailing across the shop with a clean break in the weld. I wouldnt trust that rod to hold tinker toys together, but if you folks want to keep using it because it looks pretty and easy to drag weld with, by all means carry on. Just be aware that those welds dont bend much at all before they snap and they arent as strong as the steel so there isnt any warning of impending failure.
   / Stick Electrode Smackdown (with video) #7
I think it is so strange that 7014 will pass a bend test, but have next to nothing for impact quality!
Not sure if I posted these test results of a 7014 weld here or not.
   / Stick Electrode Smackdown (with video) #8
I think it is because it is so hard that on a bend test where the coupon material can bend, the weld doesnt have to bend a lot. Most of the bending is in parent metal, whereas when you force the weld to elongate, it wont and just snaps. It has the 70 KSI tensile on straight pull, just no ductility. I havent looked up the stats on it, but I would bet it hasnt much elongation before breaking.
   / Stick Electrode Smackdown (with video) #9
Looking at some literature I have from Lincoln,
Fleetweld 47, (7014)
"As Welded"
Yield point PSI. 60-73,000
Ductility - % Elong. In 2" 20-28
Charpy V-Notch Toughness Ft. Lbs. 51 at 70-degrees.
JetWeld LH-73, (7018)
"As Welded"
Yield point PSI. 60-86,000
Ductility - % Elong. In 2" 22-32
Charpy V-Notch Toughness Ft. Lbs. 20-56 at 20-degrees.
   / Stick Electrode Smackdown (with video) #10
"As Welded"
"As Welded"
Sorry, I did try to google to learn more about how to interpret these but now my mind is spinning. Layman's terms anyone? :D
Metal Sunflower Lawn Art (A55853)
Metal Sunflower...
Hustler 60in Zero Turn Mower (A55851)
Hustler 60in Zero...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
KOMATSU PC138US LC EXCAVATOR (A52707)
KOMATSU PC138US LC...
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
