Steps for painting tractor
/ Steps for painting tractor #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Ok im going to paint my 3910 ford tractor. Im planning to use Omni AU urethane base clear. What steps should i use to clean and prepare metal? Also what primer should i use. I heard a etching primer is the way to go. Also using all Omni line products. Thank you
Ok i have a friend that finally has about 75 percent of the work done on my Ford 3910. We decided to use PPG Del Fleet epoxy paint and primer. Chasis looks sweet and cant wait to see her finished. She only has a little over 700 hours on her but sat outside for a period making her look rough.
/ Steps for painting tractor #4
Looking good! That epoxy stuff requires a little prep to remove any surface dirt/debris (a good pressure washing is usually enough) but sticks to just about anything (including your lungs so plan accordingly). I'll be painting on old JD 2020 soon (if it warms up and quits snowing).
/ Steps for painting tractor #5
Wow that looks good.
When you say stick to it is that just while its curing out I hope?
Were getting closer. Sheet metal complete by next week.
Well we finally finished her up. It turned out completely beyond my expectations. They guy helping me do the work is fantastic and really takes alot of pride in his work. The PPG Delfleet Essentials is also the best paint used to date as it flows on nice and sticks like crazy glue. Tractor has just under 800 hours but looks like it just rolled off the show room floor. Another attribute is the PPG Ford Blue matches the OEM Ford II stickers almost perfectly meaning the blue must be very close to factory. Now how in the world am I going to get her dirty? Lol
/ Steps for painting tractor #10
That is truly a great looking tractor. The Ford 3910 has always been one to admire. Good job.
/ Steps for painting tractor #11
Looks great!
/ Steps for painting tractor #12
That is a very nice paint job. Those Fords are beauties when painted up. I like how you took the time to disassemble and paint everything right.
/ Steps for painting tractor #13
Great job !!!!
/ Steps for painting tractor #14
That's a fantastic looking job you did there...I love my Deere, but there really is nothing quite like brand spanking new Ford blue. VERY NICE!!!
Sent from my LGL35G using TractorByNet
/ Steps for painting tractor #15
Back in 2012 when you posted it looks like you didn't get any input on how to prep. Sorry about that. Do you mind telling how you went about it?
/ Steps for painting tractor #17
Impressive restoration job -- now its time to put it to work again!
No worries I just kept reading up on stuff from different forums till I felt comfortable with which route to take. It came down to wanting a very adhesive paint and one that would last a long time while still looking nice. A friend of mine did all the work I just did the research to help him get started. He basically took everything apart and cleaned using a degreaser, sanded where needed cleaned again and again till it was right. Then proceeded with primer etc per PPG's directions. Sheet metal and wheels were sand blasted and prepped. He actually had a friend thats into auto body work and paint do all the sheet metal so it was a group effort. The kicker though to the entire deal is that both guys took a personal interest in the project to make it as perfect as possible so i cant say enough about their efforts. I know a great deal about correct paint colors, and specifics of these tractors right down to the correct colored zinc coated wheel bolts etc so was responsible for these type details. I have collected tons of literature, manuals, original brochures etc which helped greatly. So it was definitely a group effort.
/ Steps for painting tractor #19
We could all use friends like that. I would say that that it looks better than new. Congratulations!
Here are the paints and color numbers. Ford tractor blue and gray
