Step by step for turning a large tractor tire inside out?
   / Step by step for turning a large tractor tire inside out? #1
KYErik
Platinum Member
South central IL
1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I'm using a 38 inch rear tractor tire and need to turn it inside out to use it for a flower bed. I already have the sidewall cut out and have spent 4+ hours on attempting to invert it. I am using an 80hp JD 2930 with FEL and adjustable pallet forks.
I will try to explain my first 3 attempts: First I tried chaining one end to the top of my 3 ph dirt scoop. See attached photo.
Then I tried standing the tire up on its end in front of two round hay bales and trying to push the tire into the space between the two bales. I was able to turn half of the tire inside out, but then I placed it on the ground and attempted to finish the job, but it righted itself.
Then I drove onto the tire with my Ford 4000 and attempted to use chains to lift the cut edges and chain them into position.
Any other suggestions? I also have Case 530 backhoe that I can use in the process.
I have read on other websites about how you can place the tire in a concrete culvert and pull it through using chain tied to a rim (but I have no 48" culvert). I have also read that some people use a front end loader to invert a large tire, but I can't find a video, photo or a good description about how it is done.
   / Step by step for turning a large tractor tire inside out? #2
YouTube has videos on turning a car tire inside out. Maybe some useful ideas there. Just have to use bigger tools :)
Bruce
   / Step by step for turning a large tractor tire inside out? #3
Explosives should do the trick.
   / Step by step for turning a large tractor tire inside out? #4
That looks to be the equivalent of shoving a wet noodle up a bobcats *** in a phone booth. Good luck op! I'm sure with persistence it will work out!
   / Step by step for turning a large tractor tire inside out? #5
tag for updates.. I want to know how it turns out.
brian
   / Step by step for turning a large tractor tire inside out? #7
The guy says ok a lot in the clip.
Mossroad- thanks for the link- I had seen that video but this tire is too tough to manhandle (by hand) and even begin the folding process.
The pics in this article have given me some ideas of what to try next: FARM SHOW - Simple New Rig Turns Tires Into Feedbunks
   / Step by step for turning a large tractor tire inside out? #9
WOW! :laughing:
Looks like he's cutting off the bead on the top side of the tire, chaining the top down over the outside of the tread, then pushing the bottom bead up and through the tire. Pretty neat! Thanks for the link. :thumbsup:
   / Step by step for turning a large tractor tire inside out? #10
You got something against RR ties or 6X6's?:laughing:
You sound determined, I'm following this one :thumbsup:
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
CATERPILLAR 740B OFF ROAD DUMP TRUCK (A52705)
CATERPILLAR 740B...
(APPROX 18) 2" X 6" X 68" TUBING (A54756)
(APPROX 18) 2" X...
JOHN DEERE 85G EXCAVATOR (A52705)
JOHN DEERE 85G...
2009 Ford E-350 Cargo Van (A55788)
2009 Ford E-350...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
