Steiner hydraulic system troubleshoot
   / Steiner hydraulic system troubleshoot #1
Steiner S-20
Hi I recently acquired an older Steiner S-20, I believe it is a 1987. I am currently in the process of restoring and I have run into the issue that my front lift will only operate in one direction. It will only lift and will not press down. In fact, to get it to lower I have to hold the switch down and stand on the front fork to get it to go down. I believe it “floats” just fine but it will not push down and lift the front tires off the ground when the blade or deck is attached. Does anyone know if this is an issue with the hydraulic lift cylinder or the switch? I have read about the switches going bad and kicking out of the float position but mine seems to stick in float just fine.
   / Steiner hydraulic system troubleshoot #2
What switches? don't they use a lever?...... we are talking about hydraulics right?...... a valve maybe stuck, it should be up down and then float...... jim
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
1973 Fontaine Lowboy (A53314)
1973 Fontaine...
1985 John Deere 4050 (A53314)
1985 John Deere...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2000 GMC 3500 Bucket Truck (A47477)
2000 GMC 3500...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
