STEIGER TIGER ST470
   / STEIGER TIGER ST470 #1
Jimbrown
Veteran Member
Tombstone Az
KIOTI LK30
Some guy has two of these for sale inthe local paper...What the heck is it? Claims they are 525 HP ??
   / STEIGER TIGER ST470 #3
Stieger was one of the first commercially successful high horsepower 4wd's. They used "off-the-shelf" components in the drivetrain to simplify production and hold down cost. (components for over-the-road trucks, off-road trucks, and construction equipment) The "assembled components" construction concept made them a breeze to work on. At different points through their history, Stieger built 4wds for several "big names" like Ford, IH, and others. Case/IH (now Case New Holland) bought Stieger. You'll find the STIEGER nameplate still on todays Case/New Holland 4WDs
   / STEIGER TIGER ST470 #4
One of the most amazing feats of power I have ever witnessed was watching a Steiger tractor pull a 24 bottom plow at the farm show when I was a teenager. Just absolutely awesome.:D :D
   / STEIGER TIGER ST470 #5
Steigers are a sweet machine. I have logged 100's of hours in them. They were by far, my favorite big 4x4 tractor to operate.
The Case/IH Quadratrack (Steiger) is totaly awesome!!
   / STEIGER TIGER ST470 #6
The ST470 Steiger is a BIG tractor. Steiger used the huge KTA-1150 Cummins engine for this machine. That engine in the ST470 was only rated at 470 horsepower...I say only because that engine was sold in other applications at 600-hp. The seller says the tractor is 525-hp and the engines may have been upgraded to the 525-hp at an overhaul. 525-hp was a very common rating for the Cummins KTA.
   / STEIGER TIGER ST470 #7
Actually Versatile was the first to hit the market with Lego build style tractors. JD tried it with the Wagner tractors but failed. Later they tried it again with the 7020 series, based on the 5000 (??) series wheeled tractors to use common engines and rear ends, which had more succes in the market.
   / STEIGER TIGER ST470 #8
I'm not finding much on the "start-up date" of Versatile, not even in Nebraska test results. The first Wagners were built in 1957. It was 7 years later when Deere started selling re-badged Wagners. Before Deere took on the Wagner line, they built their own 4wd, the 8010/8020. They weren't very successful. When the 7020 and 7520 made the scene, the market was primed for the giant 4wds. The first 8010 was shown to the public in the fall of 1959 at a show in Marshalltown Iowa. Steiger Brothers were farmers from Fargo North Dakota. They built their first "component built" tractor in 1957. IH introduced their first attemt at big 4wd power in 1961. It was a re-hash of components from their large 4wd construction equipment for the most part.
   / STEIGER TIGER ST470 #9
According to the Versatile web site I found the first prototype was built in 1965 and production was started in 1966.
   / STEIGER TIGER ST470 #10
I didn't know Steiger and Versatile ever had anything to do with each other?? Are you sure the date is not the production of the first Versatile 4wd tractor?
murph
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
(2) REFRIGERATORS (A51248)
(2) REFRIGERATORS...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
2016 Utility 102"x48' Flatbed Trailer (A50123)
2016 Utility...
