Steering
   / Steering #1
Skeeter9792
Mahindra 7520
Hey guys need some help please . I just recently bought a 2004 Mahindra 7520 and noticed that the steering just quits working. Put fluid in works fine and in a little its gone again. So i have replaced the seals in the HSU ( Hydraulic steering unit ) checked it today when i got home from work and fluid gone again. What am i missing ? No visible leaks that i can find any where . Is there other seals that i need to replace or should i have just replaced the entire HSU ? Any help is much appreciated
   / Steering #2
Is the steering system attached to the hydraulic and or transmission?
I’m not familiar with this model but it is common that the steering shares hydraulics. The other option is they share the hydraulic pump and the seal between the two veins has failed......all SWAGs though!
   / Steering
I will check this out . Thanks for the reply much appreciated
   / Steering #4
Sounds like a bad pump, It has two hydraulic pumps, stacked together, one half is the hydraulic and the other is the steering pump.
Is your hydraulic fluid level going up on the dip stick? If so i'd say pump is bad.
   / Steering
Yes it is
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2017 Jeep Wrangler Unlimited Sahara (A50515)
2017 Jeep Wrangler...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
Payment Terms (MUST READ) (A50775)
Payment Terms...
E-Z Trail 500 bu Auger Wagon (A50514)
E-Z Trail 500 bu...
