steering wheel
   / steering wheel #1
chris87
griffin
massey ferguson mf135
how do you take off a steering wheel off a Massey Ferguson MF135
   / steering wheel #2
Go to your local auto parts and buy a wheel puller. Remove the wheel not, install the puller, with a wrench it does the work pulling wheel off the splined shaft.
   / steering wheel #3
After center cap is off remove nut, have a helper pull up on steering wheel, use a large shaft with end square and flat, place on steering shaft end and strike with hammer. MAKE SURE striking shaft is straight or thread damage may happen. If threads do get nicked file or grind away bad spot so nut will go on. If shaft is long enough through nut leave nut on but have about 3 turns loose. That is how I get them off.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2022 LOAD TRAIL INC GP0240122 LOT IDENTIFIER 251 (A53084)
2022 LOAD TRAIL...
Volvo Water Truck, 3306 Cat Engine (A52384)
Volvo Water Truck...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
