steering wheel
   / steering wheel #1
chris87
griffin
massey ferguson mf135
how do you take off a steering wheel off a Massey Ferguson MF135
   / steering wheel #2
Go to your local auto parts and buy a wheel puller. Remove the wheel not, install the puller, with a wrench it does the work pulling wheel off the splined shaft.
   / steering wheel #3
After center cap is off remove nut, have a helper pull up on steering wheel, use a large shaft with end square and flat, place on steering shaft end and strike with hammer. MAKE SURE striking shaft is straight or thread damage may happen. If threads do get nicked file or grind away bad spot so nut will go on. If shaft is long enough through nut leave nut on but have about 3 turns loose. That is how I get them off.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2025 CFG Industrial 680 (A50123)
2025 CFG...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2002 FORD F-350 LARIAT SUPER DUTY TRUCK (A51247)
2002 FORD F-350...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
