Steering went out on Case 580B CK - need help!
   / Steering went out on Case 580B CK - need help! #1
mz0dw4
1980 Case Backhoe 580B C/K
I have a 1980 Case 580B shuttle backhoe and the steering quit working. I added oil and I can spin the steering wheel endlessly and wheels dont turn. I lifted the front wheels off the ground and can get it to turn right and left with no load, but I have to spin the steering wheel way too many times to get it do it. Any suggestions on where to start troubleshooting would be appreciated. I have a manual of how the steering system is put together. Should I get a pressure gauge to test pressure from the pump, or is there some other way to see if its maybe the front cylinders. Should they turn when the engine is off? I've attached a picture of the steering steering overview.
Thanks
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
Adams 5 Ton HC Spreader (A53472)
Adams 5 Ton HC...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
