Steering problem with JD650
   / Steering problem with JD650 #1
flytoboat
Southern Illinois
1981 JD 650
I am going to buy a 1981 JD 650 4WD from my Brother-in-Law. It has power steering and when you turn the steering wheel, the engine bogs down considerably. Also, the wheels turn much further to the left than they do to the right. Any body out there seen this problem and offer help? My search of the forums didn't turn up any thing like this.
TIA.
Don
   / Steering problem with JD650 #2
Check to make sure the hydraulic cylinder isn't bent, as well as any of the steering linkage. That's what it sounds like it could be anyway. I assum the lift works just fine, right? If so, that should be an indication that the hydraulic pump is working fine. One other thing that comes to mind is to see if you can verify that the hydraulic plumbing going to the power steering cylinder was done correctly. That may require a trip to a JD dealer, or maybe a look at the service manual. Let us know what you find.....
Tahnks for your response, KEBO. I'll try to check it out this weekend and let you know.
Don
2009 Mercedes-Benz C300 Sedan (A48082)
2009 Mercedes-Benz...
2021 Chevrolet Silverado 1500 LT Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2004 Ditch Witch RT70M Ride On Trencher (A50860)
2004 Ditch Witch...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
Fuel Tank (A50860)
Fuel Tank (A50860)
