Steering Housing
/ Steering Housing #1
Hertenstein
Did I see where someone put regular gun grease in their steering housing? I have a L1500 and there is a leak and I can't find it. The grease would not seep out like the 90w gear oil.
Best regards,
Hertenstein
/ Steering Housing #2
i see people bring gear boxes in the shop that turn 3000 rpm packed with axle grease. they work for a while but they allways end up with me. pay me now or pay me later. its true a steering box turns very slow but its full of high dollar parts. let your heart guide you amen
/ Steering Housing #3
We commonly see oil leaks from the steering box of L series.
If left in the weather ,rain water finds its way down the steering shaft and fills the tube with water. It will find its way past the top seal and into the steering box. water goes to the bottom, oil sits on top and leaks out.
Because these are invariably used tractors, the old owners in Japan are not big on maintenance,and as you dont know how they were treated in the past, its best to assume the worst.
The remedy is to dismantle the steering box, clean, replace bearings /seals etc. Reassemble and fill with 90 or 140 grade
steering box oil.
Grease may work for a while, keeping in mind the relatively low hours many small acreage tractors actually work. But its far better to fix it properly, before sectors and recirculating ball carriers fail, which they will do ,when lubricated by water.
Keep the tractor stored under cover, give it some basic maintenance, and it will reward you with many years of hard labour.
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
