steering drift?
/ steering drift? #1
gray
Upper Peninsula of Michigan, on the shore of Super
Kubota L48 tlb
Is it normal for a tractors steering wheel to slowly have to be turned to keep the wheels tracking straight?
A post on the JD forum reminded me of this observation.
Example: Going down the raod at about 15mph. To keep the wheels tracking straight, I have to slowly turn the steering wheel around and continue this process to stay on track. Are all power steering set ups like this? My cars and trucks aren't.
This may be a classic stupid question but I have to know.
/ steering drift? #3
You didn't mention what tractor you are experiencing this with, but this is common with orbital steering found on the larger tractors.
/ steering drift? #4
It is also possible that you have unequal air pressures in the front tires. Sumpin to check.
I gotta leaky valve stem in a machine and if I take my hands off the wheel, it want's to go right back into the barn.
/ steering drift? #5
somewhat common but it is a fault in the orbital valve. Shouldn't be happening in a new tractor. No it is not tire air pressure.
/ steering drift?
Folks,
It is a L48 Kubota and it's new. About 50 hrs.
I have read now that it may be normal but in one thread it stated it should not show up in a new tractor?
Should I call the dealer and inquire?
/ steering drift? #7
<font color="blue"> Example: Going down the road at about 15mph. To keep the wheels tracking straight, I have to slowly turn the steering wheel around and continue this process to stay on track. Are all power steering set ups like this? </font>
I have a JD 4610 and mine isn't like that.
At first I thought you were talking about the steering wheel not coming back to the same place every time. Mine doesn't do that but, from what I understand, that's common.
/ steering drift? #8
In short, for a tractor that new the orbital valve is probably unbalanced or missadjusted. Your orbital is either not holding pressure in the cylinders or it is diverting flow to one of the cylinders when it shouldn't. Either way it is not functioning correctly.
Sometimes they can do funny things like spin the steering wheel in a feedback type orbital! Orbital PS systems don't function like a typical PS system.
Ken
/ steering drift? #9
Hey Ken,
If that were the case, could he raise the front tires off the ground (with tractor running) and the wheels would turn on their own? Or would that be too simple?
/ steering drift? #10
That would be the case but I doubt it would happen under no load like that. The only other possibility depending on the steering cylinder set up is the seal is gone and the machine will always not want to hold a straight line.
I'm assuming at 50hr the cylinder is pristine, but ya never know /forums/images/graemlins/grin.gif
Ken
/ steering drift?
i am getting part of the picture here. Just a bit more info. may help.
Going down the road, in about 2000ft I am turning the wheel one revolution to keep it tracking straight. The cylinder looks good. It has done this from day one- or two.
Never noticed much of anything while digging or loading. The wheel never returns to the same place.
Any more info would be helpfull. Thanks.
/ steering drift? #12
At about 70 hrs. my BX 2200 did the same thing. I had to keep turning right to keep it straight. Dealer replaced the cylinder.
/ steering drift? #13
The answer may lie in do you have to steer up the crown in the road? Is the drift always the same direction? If it is always the same direction it is most likely the valve. If you don't correct the steering and it always just wants to go downhill on the crown of the road it is likely the cylinder.
Ken
/ steering drift? #15
Sounds cylinder most likely cylinder if it uses one double ended steering cylinder. Did you say it is still under warantee?
Ken
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
