Steering Cylinders
   / Steering Cylinders #11
/forums/images/graemlins/laugh.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/tongue.gif
FOURTEEN;
Great picture!! I love it. Now I understand what the famous PUCKER effect is. Could you perform an experiment for me????,Can you recreate the same extreme pucker in the same location on your property and while the tub is suspended in the air disconnect the left (outbound) steering piston/cylinder from the front mounting bracket, and let me know what the result is.
   / Steering Cylinders #13
OK!
One steering cylinder is connected and the other isn't!!
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Steering Cylinders #14
Those are definitely double acting cylinders, they have two hoses on each end.
   / Steering Cylinders #15
/forums/images/graemlins/confused.gif I see two double acting cylinders with one hose on each end! Two cylinders, four ends, four hoses!! /forums/images/graemlins/confused.gif
   / Steering Cylinders #16
"" I do not know which side is missing. ""
/forums/images/graemlins/smirk.gif It's the one that isn't there!! /forums/images/graemlins/smirk.gif
   / Steering Cylinders #17
There is little pressure on the ends of the steering rams. All of the weight of the tractor is in the center joint.
   / Steering Cylinders #18
I was at the plant today and their was no mount on the other side but they change the way they have been mounted. The single steering cylinder is just like this one on the 422. Pretty neat uh?
   / Steering Cylinders #19
here's another pic of the new stearing cylinder
UNUSED WOLVERINE SB-12-72W 72" HDY SCREENING BUCKE (A57193)
UNUSED WOLVERINE...
2018 John Deere 1653 (A55315)
2018 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
(2) SPACE-RAY INFRARED HEATERS, INDUSTRIAL (A57192)
(2) SPACE-RAY...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1989 AM General...
