Steering cylinder seals on a John Deere 2750
   / Steering cylinder seals on a John Deere 2750 #1
Fishincoach
John Deer 850
Any idea of a rough cost to repair leaking seals on the steering cylinder of a John Deere 2750?
   / Steering cylinder seals on a John Deere 2750 #2
Is it a 2wd or 4wd? Are you doing it yourself?
2wd, might do it myself, depends on the expertise needed. It is on a tractor for sale at a good price.
   / Steering cylinder seals on a John Deere 2750 #4
Thanks Tractor Tech, with both sides leaking and the right side leaking bad will that impact the operation of the brakes and the 3pt lift? I am going to check out the tractor this week, If the motor sounds good, if I can detect very little blow by I am going to buy the Tractor. The hour meter says 10462 hours, is that too many to be worth the effort and money?
   / Steering cylinder seals on a John Deere 2750 #6
It could affect the brakes, but not the 3pt, except by the fact that it might be low on oil due to the leaks. Make sure and check the chrome rods on the cylinders for scratches or scores that a seal kit won't remedy.
10,000 hours is a lot of hours on a tractor. Pretty much the average to high average for a 2750. Either get it for a good price and inspect it thoroughly or pass. Ask if it has had a rebuild on the engine, transmission or PTO.
Good luck!
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
Electric Mobility Scooter (A51694)
Electric Mobility...
2011 GMC SIERRA 2500HD (INOPERABLE) (A52472)
2011 GMC SIERRA...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
