Steering Cylinder rebuild note
   / Steering Cylinder rebuild note
Got all the parts for both cylinders on Tuesday. Then the tractor stopped acting up. Must have been debris.... But standing by in case.
   / Steering Cylinder rebuild note #13
When mine were causing problems (mainly causing the loader arms to drop catastrophically since the steering has priority), it was intermittent. When I opened them up to repair them, I was amazed that they worked at all.
Ken
Well, rebuilt the cylinders today. Hardest part was getting one of them to come apart... But, no good deed goes unpunished.
First, not sure why they had me replace the aluminum plunger. Complete mystery to me on that one.
Second, on both plungers the first seal was broken. OK. Thats OK, I get it. But what was a real bummer is that one of the broken seals was missing an inch out of the 3 inches of rubber. It was not in the catch pan, and was not in the tube. Which means.........
I was tracking it all back and all the hoses end up in the steering control. Frig. Now what....
   / Steering Cylinder rebuild note #15
Mine were also missing pieces. Hopefully at some point they end up in the filter.
Ken
   / Steering Cylinder rebuild note #16
I am not understanding your use of the word plunger.
Is that the same as a piston that has the o-rings seals on it?
The cyl is not part of the seal lit.
Did you ask for that part or did they tell you that you must replace the cyl also?
Sorry JJ, Yes, Piston (not plunger).
I did not ask for it but they recommended it. I think I was robbed. What was worse is that they piston is soft aluminum. They package 2 in a bag. In shipping they bang against each other and the lips have little dings.... A little sand paper and we were squared away but none the less....
   / Steering Cylinder rebuild note #18
Soft aluminum should be fine since they are not supposed to come into contact with anything. However, once the o-ring fails, the aluminum piston might see a little wear from fluid squeezing by.
Ken
   / Steering Cylinder rebuild note #19
If your piston was not damaged, I would have sent them back for a refund, but since you touched then up some, it is probably to late.
Most salesmen will push a sale as they have to eat also.
As far as where that missing piece of o-rings is, could be anywhere.
You may find it soon or years from now.
Can you take a strong light and look in your tank and see if you can see any thing.
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 KOMATSU PC138USLC-8 EXCAVATOR (A60429)
2008 KOMATSU...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
iDrive TDS-2010H...
