Steering cylinder leaks oil
   / Steering cylinder leaks oil #1
Ppadin
Messy Ferguson
Massy Ferguson cg 2300 steering cylinder leaks ,where to buy repair kit
   / Steering cylinder leaks oil #2
I've had the steering cylinders fail due to leaky seals on several small Kubotas. Don't own a GC. I think (regardless of brand) most any good tractor repair shop has access to seal kits and can do the work. I'm not into hydraulic cylinder refurb but if you are go to the AGCO parts contacts (available from any dealer) and get the diagrams and the part numbers. They are probably multi-sourced once you get that info. For my aging self, I just have a local shop do it. Not terribly expensive.
thanks
   / Steering cylinder leaks oil #4
Here is the parts book and an earlier TBN post addressing your issue.
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
JOHN DEERE 560M LOT IDENTIFIER 37 (A53084)
JOHN DEERE 560M...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
