Steering cylinder leaking
   / Steering cylinder leaking #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
The steering cylinder attached to the left tie rod on my 1025 is leaking. Should be covered under warranty; I'd think. Got a note to call JD service on Monday. Been leaving small hydraulic fluid puddles underneath the cylinder when I park it.
Wonder if anyone else has had this problem on 1023 or 1025?
Ralph
   / Steering cylinder leaking #2
Not on those models, however. I did have what the tech said was an "interior" leak on my old 4320s steering ram. They replaced (under warranty) the cylinder and all was well.
Good luck
Wasn't the steering cylinder. One or two of the heater hoses was leaking a tad of antifreeze. Hadn't used up all the fluid in the overflow reservoir yet. He just tightened the clamps. Factory hadn't tightened them property.
It's propylene glycol. Doesn't seem to have any smell like ethylene glycol has. Figured it was hydraulic fluid, as it was dripping off the right end of the hydraulic cylinder on the steering.
Ralph
2013 MAXEY TRAILER MFG UTILITY TRAILER (A53843)
2013 MAXEY TRAILER...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
