Steering column cover rusted bolts
   / Steering column cover rusted bolts #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Just an FYI for anyone that owns a Kioti that has a steering column cover on it. If you use your tractor in the rain or leave it outside the 4 bolts that hold the steering column cover will rust up and you will have difficulty removing them should you need to take this cover off. Today I happened to notice that the four holes in the top of the cover were full of water. Down under are the 4 bolts that go into metal nuts that are extruded into the plastic cover. All four of my bolts were rusted up really bad. I blew the water out of the holes, sprayed Nut-buster into them and waited an hour to remove the bolts. I plugged the 4 holes with silicone. The bolts were put back into place with Never-seize on them.
   / Steering column cover rusted bolts #2
Or, you could go stainless. Then they won't even rust, never mind seize.
I thought of that too but that would mean making a special trip to Tractor Supply for the bolts. I have a few cans of Never-seize in my garage that I use on a lot of things. I do not know what the nuts are made out of.
If they are steel the stainless bolts can still rust in place.
   / Steering column cover rusted bolts #4
I use it for as little as possible, only cuz it's so messy and gets more where it shouldn't be. I use white grease, food grade grease, regular grease and for severe duty or important things, anti-seize.
A little bit of anything, is infinitely better then nothing.
I agree, Never-seize is messy if you get it all over the place or on your hands. I've been using it for over 30 years now on non-moving parts.
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
JOHN DEERE 333G SKID STEER (A52472)
JOHN DEERE 333G...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
1268 (A50490)
1268 (A50490)
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
