steering binding up
/ steering binding up #1
Blackfoot
North Central Wa.
Cub Farmall,Farmall A,Ford 8N,MF35
Hello, I have a FM35, and the steering started binding up again. It did the same thing about a year ago and then just stoped and has worked fine since. It will work fine for a little bit and then I can only turn it one way, and then it will work just fine and than it will start it all over again. It stated doing this when I was piling bitterbrush on a steep side hill. I can't see anything that is bent or broken. can anyone help me with this problem.....Blackfoot
/ steering binding up #2
Not familiar with that machine. Is it too heavy to put the front end up on jack stands and start it up. Then crank the wheels both directions? You might find a dry linkage or something. If you do that make sure it is blocked up pretty well and the stands are far enough away from the wheels to keep from getting knocked out. By the way is that a MF 35 instead of FM 35? I did a google on both and found Massey Ferguson 35. The one I saw looked like kind of an vintage tractor. I would think that there might be a cracked steering cog if that is how they do the steering control.
/ steering binding up #3
can you post a picture of the steering linkage on your tractor (probbaly just in front of the radaitor if you have power steering)??? dad has a MF industrial 35 that had a similar problem and if it has the same linkage I probbaly know how it can be fixed...
Aaron Z
Well Aaron-Z First it is a MF35, and I always have a terrible time posting pictures, so far I have never been able to do it. But I would sure would like any information that you have as to what could be wrong and how to fix it. this is only the second time it has done it, and like I said it seems to fix itself, and then ker-blam it does it again. and this coming into spring here, I really need to get it fix as soon as I can. Blackfoot
/ steering binding up #5
You might want to try flushing the steering fluid and replacing, including any fluid in the cylinders. You may get some junk out. If you do, it may be due to a cylinder going bad.
jb
Well I went out and fired it up this morning after feeding, and last night when I shut it down the power steering was still working but now it is like I don't have any power steering at all it won't even turn unless it is moving, and then it don't turn to well. I grease it regular and check things out when I get in rough country. I just don't know yet, I really don't have the funds to start fixing things that don't need fixed, if you know what I mean. So any help from you folks would sure go a long ways. Blackfoot
Well I am still working on it, I started it up again and I grabed the wheel that would not turn and turned it and now it works fine both ways, jacked up. So what do you guys think? I really need to fix this as I do not want this to happen in a spot where the jump factor is involed. Blackfoot
/ steering binding up #9
Blackfoot have you posted this question on the Massey Fergosun forum where they are more familiar with the MF 35? Sounds like Aczlan may have an answer though
/ steering binding up #11
I agree.. FWJ is probably quite familiar with the MF mechanical steering and the pow steering.
I have a MF manual at home that will covert he mech steering only.. but am at work.. etc.
soundguy
/ steering binding up #12
ok, made it out to my parents place today and got some pix... I apologize for the quality, I forgot my real camera and had to take them on my phone.
I numbered the significant parts in the picture, the numbers are the same in all three pictures, the first "The Big Picture" was taken from the front, the second "low Front" is a closeup of the steering arm and the third "top back" was taked with the camera above and behind the hyd lines in the first picture.
How it works:
in "The Big Picture" #3 is the rod coming from the steering box under the steering wheel, it connects directly to arm #4 which slides over shaft #10 (IIRC it is held on with a C clip, #4 is not splined and spins freely on shaft # 10
note: if you remove arm #1 and disconnect linkage #6 TIE THE STEERING WHEEL IN PLACE, that way someone does not do like I did and spin it. spinning the steering wheel causes the (steel) linkage #6 to meet with the (copper) radiator... this can cause bad things like the hole (#9 in the "top back" picture) to happen.
anyways, when you turn the steering wheel it moves #3 which moves #4. #4 moves tab #8 which is allowed some slack by the bolt #2 and its companion on the other side, this slack allows arm#5 to move linkage #6 and actuate the power assist cylinder #7 which then pushes on arm #1, arm #1 is splined, possibly keyed (my memory is a little but fuzzy on this as it has been ~10 years since I took this apart, that was at the age of 12) and the splines on arm #1 fit into the splines on shaft #10 and turn it, the other end of shaft #10 is welded to the plate that the tie rods bolt onto.
what your problem could be, based on my understanding of this and of your description:
if you dont have enough slack on bolt #2 and its mate when you turn the steering wheel it wont be able to push on the linkage #6 and thus the power assist never happens.
OR
if your linkage (5, 6) is sloppy it may not trip the cylinder.
OR
if the place where 7 connects to 1 is worn too much it could let the cylinder turn off before doing any work.
OR
where arm #4 hooks onto shaft #10 could be worn and be twisting instead of pushing on #5/6
how I would troubleshoot it:
1. check all the attachment points in the pictures for wear.
2. remove #6 and CAREFULLY push/pull on it with the tractor running, this will tell you if the hyd part works.
3. put the front end up on some kind of blocks to get the weight off of the tires, this will allow you to check how #1 and #4 fit on #10.
Hope this helps you.
Aaron Z
Hello Aaron, Well I sure thank you for all of your time, But we have differant tractor parts in the way of how things work. On my tractor everything that makes things turn is in the steering column under the steering wheel. I checked the pump out and everything seems to be working ok with it. So it looks like I will be rebuilding the guts. I got a book on this tractor and the trouble-shooting chart suggest that with it only wanting to turn one way, it is either a faulty control valve thrust bearing or sticking or binding valve spool. I think I will overhaul the whole unit. Thanks again,,,,,badlybent
/ steering binding up #14
Thrust bearings can certiantly let parts bind up, depending on the design of the steering system.. ( IE.. wormshaft and sector arms.. etc.. )
soundguy
/ steering binding up #15
You can certainly do what you wish....however if it was me....I would send Farmwithjunk a private message and ask him about the problem you are experiencing. Just might save you some time and grief and DOLLARS.
/ steering binding up #16
oh well, better luck next time.
hmm, is the ram under there too or just the valve??? seems odd to put the ram that far away and have to transmit that much force on the push shaft...
ok, sorry I couldn't be of more assistance.
Aaron Z
/ steering binding up #17
I wouldn't mind seeing a pic of that... most pow steer setups have a ram on the pittman arm or a draglink.. etc.... or under the front bolster.. etc..
soundguy
/ steering binding up #18
OK. This CAN be a simple adjustment issue. That ISN'T "Power Steering" as much as it is "POWER ASSIST STEERING" It depends on correct adjustment of that little turnbuckle on the very top of the assembly. It's rather complicated to explain, and I'd just confuse you further with my explaination, so, PM me with a fax # or a mailing address and I'll copy the pages from the Massey Ferguson tech manual that covers the adjustment procedures.
/ steering binding up #19
Is it a Danfosss Orbitrol unit they use ?
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2023 John Deere 400R Spreader (A63109)
2023 John Deere...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
