steering bearings for YM1700
   / steering bearings for YM1700 #1
poorboys
Hi, Im having some steering problems.. for some reason the upper and lower bearings keep going out. I ordered new bearings and put them in had the bottom pressed. I have checked for burrs on the shaft and none was found. once the new bearings were in, it immediately began to make a growling noise. in just a little while the steering was out and when I took it back apart, the bearings were just in tiny broken pieces. I have just re-ordered new ones yet again.... and I hope for the same thing not to happen.
any advise you have to offer as to a better way of doing this or what I may have done wrong? could something else be causing this? /forums/images/graemlins/confused.gif BTW, This is a YM1700 thanks, Dave <font color="blue"> </font>
   / steering bearings for YM1700 #3
Several things come to mind...Is the assembly clean, does it move freely, but with no slop when assembled, (properly shimmed and adjusted), correct lubrication? You can't just slap it together and expect it to work.
   / steering bearings for YM1700 #4
   / steering bearings for YM1700 #5
Check for a bent shaft, could be putting stress on the bearings........
   / steering bearings for YM1700 #6
   / steering bearings for YM1700 #7
My 240 did this but all of the gear oil had leaked out of it. I ended up adding a grease fitting and pumping it full with only a small amount of actual oil. This has been working for 2 years now.
   / steering bearings for YM1700 #8
   / steering bearings for YM1700 #9
Put the ball/nut assembly in the housing without the sector shaft. When it is completely tight the shaft should turn freely. My guess is that it is too tight & destroying the bearings.
   / steering bearings for YM1700 #10
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
