Steering ball joints
/ Steering ball joints #1
lukeh
Murrieta, CA
Massey Ferguson 20C (Industrial)
I have an older Massey Ferguson 20C that I am replacing the drag link and steering cylinder ball joints. In both cases, I feel like the tapered shaft is too short, and the dust boot is being crushed. I haven't even tightened them all the way yet and the boot is totally squashed. If I steer with it like this, the boot won't last the first turn!
Am I doing something wrong? Do I have the wrong ball joints (these came from yesterdaystractors.com and are the part listed for this tractor)? Is there a source of universal ball joints with extended tapered shafts?
/ Steering ball joints #2
Its likely that the hole diameter has been 'wallered' out from use. You might find a thin bushing that will fit inside the hole and keep the arms from squashing the boots. Otherwise, you might fill-in some welding metal. Or, replace with ends having oversized tapered shafts.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
