Steering Arms Loose??
   / Steering Arms Loose?? #1
miramadar
Eastern Kentucky
Kioti CK27
I was on my tractor today, a Kioti CK27, and I noticed that both the left and right steering arms are loose. I've only got about 50 hours on the tractor and I'd never noticed this before. Are they supposed to be that way?
When I say "loose", I mean that there's a bit of play in the arm when I twist them. They seem to move fairly freely against the posts that hold them in place. The tractor seems to steer fine. This just concerns me.
   / Steering Arms Loose?? #2
Are you talking about the hydraulic steer cylinders or the tie rod between the two wheels?
If I'm not mistaken the steer cylinders have ball joints on them and I think the tie rod does too. If there are ball joints on the ends then yes they should have some movement when you grab them and try to twist.
I'm talking about the hydraulic steering cylinders. They move quite a bit when I twist them. The tie rod is solid.
Thanks for the reply.
   / Steering Arms Loose?? #4
Mine twist around easily so I would say it is normal.
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
9202 (A50322)
9202 (A50322)
Miller Pro 5300 Silage Cart (A50774)
Miller Pro 5300...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
