Steel vs. aluminum cost
   / Steel vs. aluminum cost #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
When I purchased my 6X12 high-side UT with a ramp, it cost me about $450-$550 more than a comparable sized steel UT. I have always wondered how much of the additional cost of an aluminum trailer vs. a steel model is for the materials alone. Is it more time consuming to build an aluminum trailer, or does the steel trailer require more time bacause of the surface preparation and painting? Thanks.
   / Steel vs. aluminum cost #2
Material and difficulty welding are the two factors.
Chris
   / Steel vs. aluminum cost #3
If you look up aluminum pricing it is a lot more. We do a lot of our own fabrication and it is always more. We only use it where something has to be light and or not rust.
If you go to McMaster-Carrs website and look up steel and aluminum it will give you an idea. It also has guides that will tell you a little about the grades and alloys.
As already stated it is harder to weld aluminum. Any one with a stick welder can do steel with some experimenting. Thye do make sticks for aluminum, but it's hard to sue because you can't see the weld. It is much better to MIG or TIG aluminum.
We find aluminum is easier to machine sometimes so we do using when we have to mill a part.
2008 Ford E-350 18ft Cutaway Box Truck (A51692)
2008 Ford E-350...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53473)
2017 Rogator...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
Ranger Welder (A52377)
