Steel vs. aluminum cost
   / Steel vs. aluminum cost #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
When I purchased my 6X12 high-side UT with a ramp, it cost me about $450-$550 more than a comparable sized steel UT. I have always wondered how much of the additional cost of an aluminum trailer vs. a steel model is for the materials alone. Is it more time consuming to build an aluminum trailer, or does the steel trailer require more time bacause of the surface preparation and painting? Thanks.
   / Steel vs. aluminum cost #2
Material and difficulty welding are the two factors.
Chris
   / Steel vs. aluminum cost #3
If you look up aluminum pricing it is a lot more. We do a lot of our own fabrication and it is always more. We only use it where something has to be light and or not rust.
If you go to McMaster-Carrs website and look up steel and aluminum it will give you an idea. It also has guides that will tell you a little about the grades and alloys.
As already stated it is harder to weld aluminum. Any one with a stick welder can do steel with some experimenting. Thye do make sticks for aluminum, but it's hard to sue because you can't see the weld. It is much better to MIG or TIG aluminum.
We find aluminum is easier to machine sometimes so we do using when we have to mill a part.
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2013 Land Rover Range Rover Sport 4X4 SUV (A51694)
2013 Land Rover...
