steel i beam ?
   / steel i beam ? #1
tractorman99
NC
Does anybody know where you buy steel I beam ?
   / steel i beam ? #2
What part of NC are you in?
   / steel i beam ? #3
i would go to a scrap yard or junk yard in your area frirst you mite find some thing you want for less then at last you most have steel yard around you that sell steel rod etc. they usely sell I- beams.
   / steel i beam ? #4
You might also check welding shops. Sometimes they will have something left over from a job and will sell it resonable.
   / steel i beam ? #6
If you know anybody working on a construction site, steel erection jobs ofter have miscellaneous pieces of steel leftover.
   / steel i beam ? #7
I live just north of you in Lexington and I go to Davis supply on Bringle ferry road just west of Salisbury. Their nunber is in the book. HTH, later, Nat
   / steel i beam ? #8
Construction crew with left over steel :eek:
"Hey VINNY whad dat I beam layn way ovathar fur,"
RALPH, "I dont no, itd says 17th flow support, N weezze on da 19th alrdy son, jis get rid ofin it soes the inspecter dont seez it!"
lol
Mark
   / steel i beam ? #9
Look in your yellow pages under Steel Fabrication, or Steel, or Steel Supplier.
Some local Design Engineers (Structural/Mechanical) will also tell you who they like to use.
I agree you should look into a used or leftover beam first.
Fabircated steel is not 'cheap'.
Regards,
Yooper Dave
   / steel i beam ? #10
Find a company around that builds bridges. They usually have a bunch of left over used still.
Galvanized steel fence (A53424)
Galvanized steel...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
Adams 6 Ton Hydraulic Lime Spreader (A55301)
Adams 6 Ton...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
