Steak Grilling question
   / Steak Grilling question #21
500 degrees is plenty hot. My grill never gets that hot. In summer time it gets hotter then in winter. You should have a shut off valve on your direct piping. I have to open up the gas with the burners off for 30 seconds or so. Then I can turn the burners on high and ignite them. If I don't it don't get hot. After you get a little grease build up you will get flames.. Sometimes too much flame. I sear each side about 2 minutes and then turn down the heat and cook to order. I kinda like medium to well........
   / Steak Grilling question #22
IMHO, the correct answer has already been given. In order to PROPERLY sear a steak, the temperature must be at least 700 degrees.
I checked the flames, and none of them are blue, they're all orange.
Is that really a problem???
Is it possible the the folks at Lowes, just didn't assemble or set something correctly?
I'm going to go check the manual (when all else fails:)), and see if there's anything about that.
Again, thanks for all the tips,
If all else fails, I can go buy some bic lighters:)
anthony
   / Steak Grilling question #24
the flames in mine are mostly blue...it sounds like the air mixing in with the gas is not in the correct proportion. (i dont know if there too much or too little). at the place where the gas line connects to the burners is where the air mixes in (venturi tube) and it may be adjustable. check to see that the venturi tube is properly connected. Charbroil also has a website with some info including troubleshooting.
   / Steak Grilling question #25
I have a Vermont Castings grill and am pleased with it. I went out to grill our Sunday evening's steak last night and after 20 minutes preheat it was only about 300*. Flame was very low, it was cool (50's) so it should not have a gas pressure problem. Then I remembered this discussion. I got caught by the OPD!
The last time I used the grill it was raw outside, temp in the low 40's, humidity about 90% and wind at 10-15: when I finished cooking I simply turned off the tank valve and failed to turn off the burner valves. Last night I had opened the tank valve too fast and the high flow tripped the OPD. When I recalled this discussion I shut it all down then opened the tank valve slowly and then opened the burner valves one by one. Got a normal flame, NOW we can cook.
Thanks TBN!!
Vernon
   / Steak Grilling question #26
I don't have a commercial, or stainless steel, model; just a Charbroil Big Easy, 3 burner grill. It came without a thermometer and I added one that registers up to a maximum of 700 degrees. I don't think I've ever heated it to more than 500 degrees, but sure haven't had any complaints about the steaks I've done on it. And I, too, preheat the grill, sear both sides, then cook on a lower heat with the lid closed.
And I haven't been tripped up by the OPD valve yet; undoubtedly only because my brothers in the RV service business warned me about it a long time ago.:D I always turn off the burners before I turn off the bottle valve, then I open the bottle valve slowly before turning on a burner.
But today, instead of steaks, it's gonna be pork chops lightly sprinkled with red pepper.
   / Steak Grilling question #27
Where do u get this information? Who wrote the rules on what is proper?
I seldom order steak at restaurant because I prefer my own. Maybe the temperature of my grilling surface is 700 degrees but the gauge on the front is always less then 500 degrees.
I acknowledge what u say but I do not know if I agree with what is "correct".
I do not have formal education in grilling so I can offer no more then my opinion........and maybe a steak!
   / Steak Grilling question #28
Bird
I am usually more careful in shutting down but all I wanted to do that time was to get into a warm house with a still hot steak. I will take the time to shut down properly from now on, I swear!
Vernon
   / Steak Grilling question #29
Traeger Traeger Traeger....I just bought one and will never ever use anything else. This uses pellets, various wood species, and has a thermostat to set cooking temp...no gas and no electric heat after the pellets are lit....This think is amazing, simply amazing..... I'm parking the propane bbq in the garage for good.
Traeger Wood Pellet barbecue grill
   / Steak Grilling question #30
That's a fair question and don't worry, absolutely no offense. ;)
Frankly, I don't know if that is right or not but I hang out on a barbeque group on Usenet. What they say there is that the grilling surface must be 700 degrees or more to properly sear a steak. Furthermore, again they say on the newsgroup, most gas grills with less than 3 burners will not be able to produce that kind of temp.
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
1264 (A50490)
1264 (A50490)
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
