Starting
   / Starting #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I have a 1998, 1925 tractor I just purchased used. They are supposed to get me a manual on it, but I do not have it in hand yet. I am working on the manual part.
What is the "starting procedure" for a cold engine.
I have a little light on the dash that has a picture of a glow plug on it, that lights when I hold the key over.
Thanks for taking the time to explain this to me.
Al B
   / Starting #2
Generally with a manual glow plow system, you cycle the key to activate the glow plugs ( either to the first click or sometimes to the CCW direction ). This is when the light will come on. Then wait ( with the key still in that position ) several seconds up to about 8-10 seconds depending on just how cold it is. Then try to start. Experience will tell you how much glow time is required. If it starts rough, maybe next time add a second.
You want to avoid extra glow plug time. I understand this will greatly shorten their life...but, you want to be sure to get enough heat into the cylinders to allow a decent start so you don't really bang up the engine parts.
Got a block heater ??
   / Starting #3
Not knowing from your bio where you live makes it a little more difficult to help you for your conditions. The glow plugs have different amounts of time they are to be on. Some times it's only for 10 seconds but yet on some makes and models they would require 60 to 90 seconds. One thing that is critical is to have a fully charged battery as they are only at 50% of peak below freezing.
   / Starting #4
On some newer tractors, the glow plug light goes out to indicate when you can start the tractor.
   / Starting
I keep forgetting to do the Bio, but have done it now.
Clarksville, TN, just above Nashville.
About 25-30 degrees here this morning, cold, but not like many of you are experiencing I am sure.
I guess I was hoping for the light to go out thing. And did not want to burn out the glow plugs waiting to figure out that it did not.
Thanks guys.
   / Starting #6
On my NH 1920.. I turn the key CCW, and hold it, and the light goes out after a few seconds. What is the key setup on the 1925?
Soundguy
   / Starting #7
turn key to glow
I like the idea of being able to control how long the glow plugs are hot better than the timer deal. I find that one cycle is often not enough to get a good clean start.. I usually cycle the plugs a few times when it's really cold and I have not run the tractor for a few days..
   / Starting
Well, I have 4 little icons over the switch, Of course there are only 3 switch positions, go figure. My key will not turn CCW, and that Icon is the off one so I do not think mine works that way.
So, if I turn it too the icon that shows the little glow plug, and the glow plug light on the dash lights, and it is in neutural, it is cranking, so I put it in gear, held the key in that position to warm the plugs (I think) and then put it in N and crank it up. That was what the guy showed me, but somehow, I have a feeling that will not be the procedure in the New Holland manual.
I will give the used dealer a bit more time, then it will probably be worth the $30 + for the owners manual. Maybe my dealer will work something out with me??? well, maybe not.
   / Starting #9
Strangely enough.. we have some heavy equipment that functions just like that.. glow plugs flash -during- starting...
Soundguy
   / Starting #10
When in doubt it is a very easy task to remove the wire from the glow plug and hook up any 12 volt automotive bulb to test the circuit. That way you will know in which key position your glow plugs are actually fired. You will also find out if they are on a timed circuit and if so for how long the power is established on each cycle. Then reattach the glow plug wire and you will know which start proceedure to follow for your tractor in the future. /forums/images/graemlins/grin.gif
40ft Shipping Container (A49461)
40ft Shipping...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
Holden Heavy Haul Lowboy T/A Equipment Trailer (A49461)
Holden Heavy Haul...
