Starting
   / Starting #1
bennie
I have an LK 3054. When I turn the start for glow plug it heats up but when I turn to start nothing happens. Can anyone give me some advice. Battery is OK, cables terminal are clean. Thanks in advice.
   / Starting #2
Welcome to TBN.
How do you know the battery is OK? Have you done a load test on it? If not, what tells you it is not the problem?Verify good clean solid ground at the frame/chassis, for the negative cable. Also make sure the battery post cable connections are unable to be moved without a wrench- ie. snug- tight. How old is the battery? How many hours on the clock?
Did the symptoms appear suddenly or over time, and now causing a no start condition?
To those more familiar with this model, is there a main fuse, 60 amps or similar? PTO lockouts? Neutral safety switches?. Etc?
TIA,
CM
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
