Starting to disk and reclaim old cutover.
   / Starting to disk and reclaim old cutover. #1
jonbravado
Central, SC
Kubota L2350DT
hello all -
i am about to drag a boxblade w/ the teeth down over the front of the drumchopped area of my property. After i drag that for a while, i am going to disc up the place a good bit - my question is..........
i bought the 'joy of gardening' book and have been reading it in the evenings. GREAT book. He has a section on buckwheat. Should i plant this seed and let it grow to 'shade out' the native stuff there, so i can plant grass/clover seed eventually. He makes it sound like a quick way to choke out what's there, and once disked in a couple times, the soil would be better for it? any advice would be appreciated - thanks.
J
   / Starting to disk and reclaim old cutover. #2
I guess it will take a year or 2 for those chips and chunks to rot enough to be able to get any tillage tool into the ground ???
   / Starting to disk and reclaim old cutover. #3
You might want to try scraping them up into a pile to get some earth before you drop the tines down.
   / Starting to disk and reclaim old cutover. #4
How big is your property? Is it chopped enough to allow a safe prescribed burn? Prescribed burning it would clean it up a lot quicker (the logging debris) than you disking it. It would also promote grass growth more than shrubby brush. Contact your local forestry department for contacts on installing a safe fire line and certified prescribed burning contractors.
Sincerely,
Ikymojoe
   / Starting to disk and reclaim old cutover. #5
Buckwheat will work for you but make sure you plow in under before it goes to seed.
   / Starting to disk and reclaim old cutover. #6
Work up your ground and add lots of nitrogen to compensate for the wood chips. If you have deer there should be no problem worrying about buckwheat going to seed.
Winter rye also makes for a good cover crop.:D
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
