Starting problems for a NH 1715
   / Starting problems for a NH 1715 #11
Skyhook, older Shibura built Ford/New Holland tractors have slow glow plugs. 30-60 seconds in cold weather is the norm for these tractors that don't have timing circuit.
   / Starting problems for a NH 1715 #12
Just going to add to this thread based on my experience where my key switch was faulty causing a hard start. When the key was moved to the start position, the starter would engage and the engine rotated well; however, the fuel solenoid was not activating- so no fuel. But if I released the switch to the run position it would then activate the fuel solenoid and sometimes there was just enough momentum from the rotation of the engine that it would start. Drove me crazy figuring out that problem. Dealer told me I needed an engine rebuild due to no compression. That made no sense to me so after a bit of troubleshooting I recognized the switch wasn't activating the fuel solenoid in start position. Pulled the switch, opened it up and just put it back together "tighter". Think it had just worn a bit to the point some of the contacts were not touching. Removed the slop and it has worked perfectly since. Just thought I'd pass along that oddball experience, problem & solution. Never know who it may help.
Thanks for replying to this thread. I have been going nuts trying to figure this thing out. Dealer is telling me basically the same thing I am hearing from you. Where exactly did you find the fuel solenoid? I have followed the fuel line all the way from the tank to the fuel pump and I am not seeing what I would say is a solenoid. Mine is a 1715, which I can't say I know is close to a 1720. I am not a mechanic, but I am persistent to the extreme. My tractor runs excellent after it starts, I just have the surging(when it is cold and then subsides as it warms up. I also cannot start this at all if I don't get it started on the first attempt. I have to wait 1/2 hour or so kind of like it is flooded. I do know that a diesel cannot flood, so I am assuming there is excess fuel sitting on the pistons and causing this problem. Looking forward to a reply.
   / Starting problems for a NH 1715 #14
This may be a bit lengthy, so please bare with me. My 97 NH 1715 is having starting problems. About two years ago I went out to start it at an idle and it would not start. It seemed to be laboring because of the battery so I replaced the battery. It still would not start, just turning over and no fire. Out of desperation I pulled out the kill switch and tryed it and it attempted to start and then died. Just a note here, I had replaced the glow plugs, and put in new lines from the fuel tank to the glass fuel filter as well as replaced the filter. So anyway I tryed to start it again and it labored but finally started. Felt like the battery was running down, but it finally started. Another note here, this little tractor started first time every time at an idle. I used it and it ran like a top and then I parked it. The next time I went to start it the tractor would not start. At this time I took it to the NH dealer for examination. They checked the glow plugs which were fine. They checked the injectors which had some low pressures, so we replaced them. The also took the injector pump apart and put new seals in it and checked the operating pressures and they were fine. I went over to check out their work, and they informed me that it would now start everytime, but I would have to start it at full throttle and then slowly back it off as it warmed up. This seemed odd to me, but their explanation was that they felt the timing system was compromised. I have used the little tractor now for two years, in winter and summer and as I mentioned it runs fine and starts if I use a full throttle to start it. It is always plugged in when cold as I installed a block heater on it. Here's the thing, IF I do not get it started on the first try it will act like it is flooded(gas engine) and I have to wait for about a 1/2 hour and attempt it again and it starts fine. I know that you cannot flood a diesel engine, but that is what it acts like. Once again when it gets warmed up it is fine a runs like a million bucks. It only has about 800 hours on it, and I am puzzled by this. If the engine is warmed up or it is warmer out I can start it at an idle very easily. The warmer it is the better is starts. Well there you have it, I await any and all theories.
To start a diesel in cold weather, you need fuel that treated for the ambient temperature you are trying to start in, you have to have adequate air flowing into the engine as well as adequate fuel flow, you have to have a good battery that will give you good cranking speed and you have to have adequate compression and you may need a starting aid, which in your case is glow plugs. I prefer to have a block heater to warm the coolant and it helps not only the cranking process but also helps combustion start. I see you installed one so I gather you are using it..
It seems you checked out the fuel delivery system but not the air delivery. Is your air filter fairly clean? Adequate air is required for combustion and a clogged air filter will cause a "flooding" of sorts.
Are you using a winter grade diesel or do you have summer fuel in it? A clean fuel delivery system won't deliver gelled diesel fuel or fuel through an iced up filter.
Is your battery delivering adequate current to the starter to spin the engine over. Are the battery terminals clean and the chasis ground good? Is your starter in good condition?
What does your owners manual say about cold starting? Many manuals tell you to move the throttle lever to the mid range location during starting.
With 800 hours on the engine I doubt you would have a compression problem.
In cold weather (below freezing) with three hours of block heater time, our Ford and New Holland tractors start in a couple of turns. Our Kubota M4500 requires both the glow plugs and block heater to start in a couple of turns.
   / Starting problems for a NH 1715 #15
The solenoid I'm referring to is mounted to the bottom left of the injection pump if I recall correctly. (Sorry not at home near the tractor to confirm). Round cylinder with an electrical terminal. It's the solenoid that will kill the tractor. My ignition key switch wouldn't activate this solenoid in "start" but would activate in "run". Took me a while to figure out what was going on. Dealership never did. Good luck sorting this out.
   / Starting problems for a NH 1715 #16
Black smoke means there's enough fuel. I'm guessing that there's really no air blockage. What is happening is that you've got cold fuel and a cold engine and are not getting any, or not enough, additional timing advance to compensate. Not real familiar with tractor fueling systems, but with cars (I have TDIs) they have mechanisms to adjust timing based on fuel and engine temperatures: this, however, is managed via a computer (not like they are new cars, vintage is 2000).
Just musing...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
Best 30' Grain Drill (A50514)
Best 30' Grain...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
