mikelh
This may be a bit lengthy, so please bare with me. My 97 NH 1715 is having starting problems. About two years ago I went out to start it at an idle and it would not start. It seemed to be laboring because of the battery so I replaced the battery. It still would not start, just turning over and no fire. Out of desperation I pulled out the kill switch and tryed it and it attempted to start and then died. Just a note here, I had replaced the glow plugs, and put in new lines from the fuel tank to the glass fuel filter as well as replaced the filter. So anyway I tryed to start it again and it labored but finally started. Felt like the battery was running down, but it finally started. Another note here, this little tractor started first time every time at an idle. I used it and it ran like a top and then I parked it. The next time I went to start it the tractor would not start. At this time I took it to the NH dealer for examination. They checked the glow plugs which were fine. They checked the injectors which had some low pressures, so we replaced them. The also took the injector pump apart and put new seals in it and checked the operating pressures and they were fine. I went over to check out their work, and they informed me that it would now start everytime, but I would have to start it at full throttle and then slowly back it off as it warmed up. This seemed odd to me, but their explanation was that they felt the timing system was compromised. I have used the little tractor now for two years, in winter and summer and as I mentioned it runs fine and starts if I use a full throttle to start it. It is always plugged in when cold as I installed a block heater on it. Here's the thing, IF I do not get it started on the first try it will act like it is flooded(gas engine) and I have to wait for about a 1/2 hour and attempt it again and it starts fine. I know that you cannot flood a diesel engine, but that is what it acts like. Once again when it gets warmed up it is fine a runs like a million bucks. It only has about 800 hours on it, and I am puzzled by this. If the engine is warmed up or it is warmer out I can start it at an idle very easily. The warmer it is the better is starts. Well there you have it, I await any and all theories.
