Starting problem
/ Starting problem #1
sheba104
I have a jinma 224 either the starter or selonoid is bad. i am wondering if any one know which part may be bad or do i need to buy the complete starter. some times starter catch and tractor starts.
/ Starting problem #2
Sheba, welcome to the forum, You will need a good mechanic to check your problem for you, if we knew more about your machine that would help also. There is nothing in your profile as to what you have or year etc.?
Jim
/ Starting problem #3
The Jinma 200 series has a starter that is notoriously unreliable in cold weather. I presume this is a problem that you didn't have until the nights started cooling down (?). Assuming that's all it is, try heat. I stuck a 200 watt magnetic oil pan heater on the starter housing. Once the starter was fooled into believing it was summer again, the stater engaged every time.
If that doesn't do it, then maybe you're right about one of the components. If I had to choose one, I'd say solenoid - and yes, they're available separately from some Jinma parts suppliers now.
//greg//
/ Starting problem #4
Sheba104,
So you have a Jinma 224 cool.
Please describe exactly what happens (sounds) when you turn the key.
Does it just click?, spin / whirr ?, grind? or do nothing?
Come see us here click here
/ Starting problem #5
A little more info on what it is doing or not doing will get you a little more feed back.
Don't know how old your tractor is? Some of the older starters were not lubed very well when they went together a the factory, Ground connections can effect starter operation. The newer starters seem to be better. You could or can purchase a new starter assy or just parts for the one you got. You may just need to take it apart to clean and lube.
Finding the problem will help insure dependable starting ... winter or summer.
Ronald
Ranch Hand Supply
/ Starting problem
when i turn key it just make a click noise need to know steps in cleaning selonoid or installing a panic button.
/ Starting problem #7
We have the soleniods as a seperate part,how many hours on the tractor,?stored inside or outside ?
Tommy
Affordable Tractor Sales
/ Starting problem #8
Code:
a click noise
Have you checked the battery and all the connections?
/ Starting problem
tractor stored inside, checked all electrical connection
/ Starting problem #10
Click Here for information on cleaning the solenoid, starter, connections and how to install a "panic" button.
/ Starting problem #11
A "click" noise when trying to start the tractor may just be a bad battery or a bad ground. Turn on the headlights then have someone watch the headlights while you try to start the tractor. If the headlights dim, you either have a bad battery or a poor ground. If the headlights stay bright, you may have either a bad solenoid or a starter with a "flat spot" or a bad ground. To check the starter for a bad spot or poor ground try to use a jumper directly from the battery to the starter positive connection, with the tractor in neutral. If the tractor cranks you have a bad solenoid. If not, make sure that the starter has a good ground. If there is paint between the starter and the block, the paint can act as an insulator and cause erratic starter function.
/ Starting problem #12
The best thing you can do is take the starter to an alternator/starter shop that you can trust. I own a dealership in louisiana and see starter problems all of the time. I took 6 bad starters to a friend that has an alternator/starter shop hoping to salvage one or two. When I went to pick them up he had everyone of the working better than new without replacing one single part. He said that machining and set-up was horrible. We also found an alternator with a built in regulator that sells for the same price. If you need any help feel free to email me at action-equip@charter.net
2004 Ford F-150 Ext. Cab Pickup Truck (A64556)
2004 Ford F-150...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
Karcher G 2800 OC Portable Pressure Washer (A64553)
Karcher G 2800 OC...
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
